Deletes an OSPF area or all OSPF areas.
| area-identifier | Specifies an OSPF area. |
| all | Specifies all areas. |
N/A.
An OSPF area cannot be deleted if it has an associated interface. Also, area 0.0.0.0 cannot be deleted.
The following command deletes an OSPF area:
delete ospf area 1.2.3.4
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
